multiple misfires
2003 KIA SPECTRA
54,000 MILES • 4 CYL • FWD • MANUAL
GFSPECTRA
  • 5 POSTS
I have misfires on cylinder 1, 2 and 3. DTC codes P0300, P0301, P0302, P0303. I have replaced plugs (properly gapped), wires, coil packs, fuel filter, fuel injectors. No effect.
Noid light shows pulse signal at fuel injectors. Compression check shows 140 on cyl #1, 150 on cyl #2-4
Thanks for your help!
Apr 15, 2009 at 1:37 PM
JAMES W.
  • 2,394 POSTS
What is the fuel pressure reading? And, can you describe how it's driving going down the road? Please advise.
Apr 15, 2009 at 5:05 PM
GFSPECTRA
  • 5 POSTS
Bought a gauge to check fuel pressure, but the reading was erratic and fuel accumulated inside the gauge. I assume the gauge was faulty, so I don't have an accurate pressure reading right now.
When cold, the car will start but then die immediately. If I press the gas, I can keep it running, and then it will idle (very rough) once it warms up for about a minute.
When I try to drive it, it stumbles up to about 2500 rpm. Above 2500 it seems smoother and accelerates decently.
Apr 15, 2009 at 5:25 PM
JAMES W.
  • 2,394 POSTS
Well, if it were a fuel pressure problem, the symptoms would be the other way around. Good performance at low revs and poor at higher revs under load. I'm assuming you have not had a "check engine light". A problem with the cam sensor will usually trip the CEL, but many times a bad throttle position sensor won't. I'll see if I can find the TPS test specs and attach them to this post. I now sounds like the TPS may have a dead spot in it.
https://www.2carpros.com/forum/automotive_pictures/248092_03_Kia_1.jpg
https://www.2carpros.com/forum/automotive_pictures/248092_03_Kia_1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/248092_03_Kia_2_1.jpg
Apr 15, 2009 at 6:17 PM
GFSPECTRA
  • 5 POSTS
I do have CEL, codes P0300, P0301, P0302, P0303. Just misfire codes. Would a bad TPS cause misfires like that? Thanks for the spec sheet, I'll test the TPS as soon as I get some daylight.
Apr 15, 2009 at 7:58 PM
JAMES W.
  • 2,394 POSTS
The term "miltiple missfires" mean that a given cylinder is not firing. This isn't just limited to spark. a lean condition can also cause a misfire. and, a possible cause of this could be the TPS. Let me know what you find.
AND, what do you mean, "get some daylight", it's still daylight here. Pardon my twisted humor.
Apr 15, 2009 at 8:14 PM
GFSPECTRA
  • 5 POSTS
Sounds good, I'll check it out. My work schedule doesn't allow me much daylight :)
I'll post my findings.
Apr 16, 2009 at 9:57 AM
GFSPECTRA
  • 5 POSTS
Ok, TPS was slightly off the numbers you posted. I replaced it and cleared DTC codes. Started it up and it ran (didn't stall immediately like usual), but still very rough. After a couple minutes the misfire codes came back (cyl 1 & 3)
Side note, I can hear what sounds like sparks arcing to the block intermittently. It will do it for 30 seconds, then stop for a minute, etc. I started the car in the dark and couldn't see any arcing.
Apr 22, 2009 at 10:19 AM
KINGROCK
Did you ever find the problem? I'm having a misfire on my car and figured your solution may help me if you could just post the result.
Thanks!
Aug 11, 2009 at 4:36 PM
MATT BEAUCHAMP
Working on my parents 03 kia spectra that has same misfire issues. The more i messed with it the more random the misfires became, especially on cylinders 1 and 3. Started looking at the coil pack harness connector and noticed one wire wasn't pushed in as much as the other wire. Come to find oit the connector has deteriorated and is falling apart. Hoping that will fix my misfires
Feb 18, 2019 at 7:07 AM
Yep it sounds like it will. here is a guide that can help. I have seen a bad MAF sensor cause this issue as well, check out the diagrams below.
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
and
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
Feb 18, 2019 at 10:04 AM
