2001 Kia Spectra replacement of hub assembly
2001 KIA SPECTRA
SONNYMARI
Drive Train Axles Bearings problem
2001 Kia Spectra 4 cyl Front Wheel Drive Manual
Will the hub assembly off of a 2003 Kia Spectra fit properly onto my 2001 Kia Spectra? Is the Spline count the same on the bearing of the 2003 model as it is on the 2001 model?
May 11, 2009 at 4:55 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:c58997cc2e="sonnymari"]Drive Train Axles Bearings problem
Will the hub assembly off of a 2003 Kia Spectra fit properly onto my 2001 Kia Spectra? Is the Spline count the same on the bearing of the 2003 model as it is on the 2001 model?[/quote:c58997cc2e]
Here is what you do...
Call your local auto parts store and have them look up the part for both vehicles. If part numbers are the same then yes it will.
May 11, 2009 at 6:14 AM
