Brake light is staying on with an !p code what do dat mean brakes is stopping fine
Nov 3, 2010 at 5:21 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
brake fluid is most likely getting low, check fluid and if it is low check for leaks around the master cylinder and brake lines.
Nov 3, 2010 at 6:54 PM
ANNIE_50
MEMBER
[quote:4db7d2c9ce="bluelightnin6"]brake fluid is most likely getting low, check fluid and if it is low check for leaks around the master cylinder and brake lines.[/quote:4db7d2c9ce] Will check
