2003 Kia Sorento power window
2003 KIA SORENTO
80,000 MILES • 6 CYL • 4WD • AUTOMATIC
SEANJKENDRICK
Driver's side window went down and stayed down. Checked voltage to motor, with a minimal reading(1-3V). Replaced the switch and still doesn't work. Could it be the motor? The wires seem to be all intact and the other windows work with that switch.
Aug 22, 2009 at 5:10 PM
MIKE.SHRUM
  • EXPERT
  • 43 POSTS
Do you Hear anything happening when you try to roll it up. You might have to get down next to door panel
Aug 22, 2009 at 5:24 PM
SEANJKENDRICK
I have the door panel off. There is absolutely no activity in the motor. I had to unbolt the motor assembly from the door in order to get the window up and tape it.
Aug 23, 2009 at 2:38 AM
JUSTJOHNNY
after you took off the motor could the window manually go up. and did you ever find out what was wrong?.. Thanks
Sep 7, 2009 at 2:55 PM
