alternator replacement?
2000 KIA SEPHIA
150,000 MILES • 4 CYL • FWD • MANUAL
REDDOGG69
took alt off motor how to get it out area its in
Feb 26, 2010 at 8:04 PM
BLUELIGHTNIN6
  • 16,542 POSTS
This guide will help walk you through the alternator replacement with instruction for your car in the diagrams below.
https://www.2carpros.com/articles/how-to-replace-an-alternator
Feb 26, 2010 at 8:15 PM
2CP-ARCHIVES
  • 4,540 POSTS
I replace the alternator amd battery and check all the fuses and the alternator still willnot charge
Sep 24, 2020 at 12:07 PM (Merged)
CARADIODOC
  • 34,306 POSTS
Measure the voltage on the output terminal while the engine is running. It must be between 13.75 and 14.75 volts. If it is high, it is charging but there's a break between there and the battery positive terminal, usually due to a blown large bolted-in fuse. If the voltage is low, the same as the battery voltage, check for voltage on the smaller wires. Holler back with those colors and voltages with the ignition switch on and the engine off and with it running.
JESSICAMARTHEY1017
i replaced my pullies and alternator and belts and it is still making a loud squeaking noise and breaking belts can you please help me?
ERNEST CLARK
  • 1,730 POSTS
If you changed all of your pulleys and are still breaking belts, then one/more of your pulleys are misaligned, warped or loose.
You'll have to find out which one and replace it.
TEENA.FARLEY
Hi. My alternator isnt getting any power to it. Its new and know thats not the problem. I had my fusible link replaced.
PROTECH1980
  • 901 POSTS
Have you checked the fuses in the underhood fuse/relay box? Also what specific engine does this kia have?
TEENA.FARLEY
1.6 i believe. And all my fuses in the relay are ggod! Might it be something wit like the ignition module or coils?
PROTECH1980
  • 901 POSTS
What does the vehicle do, i thought the original problem was no power to Alt?
