I have a 99 kia sephia, the car accelerates really slow until about 20 mph, and is worse when it is cold both outside temp and engine temp. It runs better when the car has warmed up. It also idles in surges, like when I come to a stop the car is rocking forward. I noticed the air intake hose was cracked and replaced it. I replaced the Idle air control and throttle position sensors and it didn't do anything so I returned them. The dealership said that my exhaust was clogged but the exhaust guy I took it to said it was fine. The check engine like code was 101, which is a problem with air flow or air measurements. changed spark plugs and pcv valve, don't know what else to do, can I keep driving it safely?
May 15, 2009 at 10:31 PM
