1998 Kia Sephia Water pump
1998 KIA SEPHIA
BLACKTOKYO2002
Engine Mechanical problem
1998 Kia Sephia Front Wheel Drive Automatic 152000 miles
Where is the water pump located, are there any special tools required remove it.
May 13, 2009 at 4:44 PM
The waterpump is run by the timing belt. Here are the directions for all possible engines:
1.5L & 1.6L (VIN 5) Engines
Before servicing the vehicle, refer to the Precautions Section.
Disconnect the negative battery cable.
Drain and recycle the engine coolant.
Remove the drive belt.
Remove the timing belt.
NOTE
The power steering pump must be removed to access the water inlet pipe. Do not disconnect the pump fluid lines.
Remove the power steering pump and position aside.
Remove the water inlet pipe and gasket.
Remove the water bypass pipe and O-ring.
Remove the water pump bolts, pump and gasket.
Clean all gasket mating surfaces.
To install:
Fig. Water pump mounting-1.5L and 1.6L (VIN 5) engine
Install the water pump, using a new gasket and tighten the mounting bolts to 14-19 ft. lbs. (19-26 Nm)
Install the water pump bypass pump, with a new O-ring.
Install the water inlet pipe, with a new O-ring.
Install the power steering pump.
Install the timing belt.
Install the drive belt.
Fill the engine coolant.
Connect the negative battery cable.
Start the engine and check for leaks.
1.6L (VIN 3) Engine
Drain the engine coolant.
Loosen the water pump pulley bolts.
Remove or disconnect the following:
Drive belts Water pump pulley Timing belt Timing belt idler Alternator brace Water pump and gasket
To install:
Fig. Water pump mounting-1.6L (VIN 3) Engine
Install or connect the following:
Water pump with a new gasket. Tighten the mounting bolts to 9-11 ft. lbs. (12-15 Nm). Alternator brace. Tighten the bolts to 15-20 ft. lbs. (20-27 Nm). Timing belt idler Timing belt Water pump pulley. Drive belts
Tighten the pulley bolts to 6-7 ft. lbs. (8-10 Nm).
Fill the cooling system to the correct level.
1.8L Engine
Remove the timing belt, tensioner and idler pulleys.
Remove the water pump mounting bolts, then the pump.
To install:
Fig. Water pump mounting bolt locations (arrows)-1.8L engine
Install the tensioner and idler pulleys
2.0L Engine
Remove the drive belts.
Remove the timing belt idler.
Remove the power steering pump and use a wire to secure the pump to the vehicle so that it is out of the way.
Remove the bolts and power steering pump bracket.
Remove the alternator.
Remove the 2 bolts (D) and alternator brace (A).
Remove the 3 bolts (C) and remove the water pump (B) and gasket.
To install:
Fig. Exploded view of the water pump mounting-2.0L engine
Install the water pump.
Install the water pump (B) and a new gasket with the 3 bolts (C). Tighten the bolts to 8.5-10.5 ft. lbs. (11.5-14.5 Nm)
Install the alternator brace (A) with the 2 bolts (D). Tighten the bolts to 14.5-19.5 ft. lbs. (19.5-26.5 Nm)
Install the power steering pump bracket and bolts.
Install the alternator.
Install the timing belt idler.
Install the water pump pulley.
Install the drive belts.
Tighten the water pump pulley bolts. Tighten the bolts to 5.5-7 ft. lbs. (7.5-10 Nm)
Fill with engine coolant.
Start engine and check for leaks.
Recheck engine coolant level.
2.4L & 2.7L Engines
Disconnect the radiator outlet hose and coolant bypass hose from the water pump.
Remove the water pump pulley.
Remove the timing belt covers and timing belt tensioner.
Remove the water pump mounting bolts.
Remove the alternator brace.
Remove the water pump from the cylinder block.
Fig. Exploded view of the water pump mounting-2.4L engine
Fig. Exploded view of the water pump mounting-2.7L engine
To install:
Install the water pump, using a new gasket and tighten the mounting bolts to 14-20 ft. lbs. (19-27 Nm) for 2.4L engines and 11-16 ft. lbs. (15-22 Nm) for 2.7L engines.
Install the timing belt tensioner and timing belt.
Install the timing belt covers.
Install the coolant pump pulley and drive belt.
Connect the radiator outlet hose and coolant bypass hose to the water pump.
Oct 13, 2009 at 8:17 AM
