The battery keeps dying after I turn the car off?
1998 KIA SEPHIA
KTJINKLAYER
I think there is a short in my electric on my kia. The battery keeps dying after I turn the car off. I pulled the ground clamp off the battery and touched it to the ground post on the battery and it sparks bad. I have tried pulling each and every fuse out and then touch the clamp to the ground post on the battery and it sparks still on every fuse I pull. Any help would be greatly appreciated Thank You -Kevin
Aug 17, 2009 at 5:52 PM
SQM
  • 6,383 POSTS
It sounds like your vehicle have excessive parasitic draw (current drain).
A parasitic draw is the current drain that happens in a electrical circuit with a battery.
There is always a minimum amount of draw that is acceptable.
However due to any faulty electrical component the parasitic draw cab become excessive, like a shorted out window switch or a light staying on.
Here is a helpful video:
https://youtu.be/z5F7WpgjaRs
https://www.2carpros.com/articles/car-battery-dead-overnight
Thank you.
Aug 25, 2021 at 11:44 AM
