2005 Kia Sedona Rear Brakes
2005 KIA SEDONA
JIMOORE55
2005 Kia Sedona 65K miles
How do I remove the rear brake drum?
May 28, 2010 at 7:37 PM
MHPAUTOS
  • 31,937 POSTS
Hi there. With the wheel off you should see 2 philips headed screws, remove these, (you may need an impact driver) if the drum still does not come off, give it a sharp blow with a soft hammer, if it is still stuck there are 2 10mm threaded holes, fit 2 bolts and evenly do up this will with draw the drum.
https://www.2carpros.com/forum/automotive_pictures/61395_Graphic_147.jpg
Mark (mhpautos)
May 29, 2010 at 1:55 AM
