instructions for swapping an alternator
2005 KIA SEDONA
REVN_RX7
Six cylinder front wheel drive automatic 154,589 miles.
The diagram pictured on your site does not show the power steering pump located directly below the alternator preventing it from being taken from beneath. It also does not mention that there is only about three to four inches clearance to the fender wall/frame so no way to take it out the side. and there is not enough clearance between the engine and the A/C and radiator to bring it up top. Looks like I am going back to Kia.
May 19, 2010 at 6:46 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Disconnect the battery.
Remove all support piece above radiator, and remove hood latch support in front of radiator.
Remove only the upper coolant hose and bracket to the engine.
remove the brackets that mount A/C lines to the car body opposite the alternator. This will give you flexibility to move the radiator and mounting bolts.
Remove each of the fan housings. This should give you sufficient space to work on the alternator itself and remove it.
loosen the tension pulley, the one toward the firewall, no need to remove it but no big deal. Then loosen the bolt below it to help put the belt back on later.
Remove the alternator, disconnect the electrical and remove the mounting bracket that mounts to the engine. The long bolt on the bottom does not come all the way out but you can still remove the alternator with it wedged in the hole. Remember to put this one in first when you reinstall the new on;
Work the alternator carefully around the front of the engine and remove from the right side.
Installation is the reverse of these instructions.
Replace the lost coolant about a liter.
May 19, 2010 at 11:12 PM
