Hello and thanks for donating
The front wheel bearings are serviced with the steering knuckle as an assembly.
Remove or disconnect the following:
Front wheel
Brake caliper and rotor
Wheel speed sensor harness
Hub nut
Lower ball joint
Strut mounting bolts
Steering knuckle
To install:
1.Install or connect the following:
Steering knuckle
Strut mounting bolts and tighten them to 88-101 ft. lbs. (119-137 Nm).
Lower ball joint. Tighten the pinch bolt to 69-85 ft. lbs. (93-115 Nm).
Hub nut and tighten it to 177-199 ft. lbs. (240-270 Nm).
Front wheel
Check the alignment and adjust as necessary.
Apr 10, 2010 at 9:56 AM
