the engine shake hard. however in idle the engine run smoothly?
2004 KIA SEDONA
ZULANDERS
  • 8 POSTS
Problem:
1) when press a little hard at the pedal to make the car move, the engine shake hard. however in idle the engine run smoothly.
2)engine jerking when start acceleration (after the mpv had move)
Error code detected:
P0150 - O2 sensor circuit malfunction (B2S1)
is it have anything to do with the valve control?
Aug 17, 2010 at 4:03 AM
SQM
  • 6,383 POSTS
It sounds like the engine might be misfiring under load (acceleration).
When the ignition components like spark plugs, coils starts to fail they will misfire when you accelerate as there is more load on those components. Many times you will have good idle but will misfire as the vehicle starts to accelerate.
https://youtu.be/UKB-ytgbnzU
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
Check the spark plugs and make sure they are in good condition and the gap is correct.
Spark plug gap: 1.0 - 1.1 mm (0.039 - 0.043 in.)
https://www.2carpros.com/articles/how-to-change-spark-plugs
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Thank you.
Aug 21, 2021 at 10:45 AM
