i bought the van used a month ago the said they changed the timing belt and the fuel pump and intake gasket ... first the starter acted up not wanting to turn the engine over i had it rebuilt and out of the blue the thing won't start cranks very well checked spark.. it does have spark. checked plugs and the are completely dry so i checked fuel pump.. when u turn key on it makes a thud sound so i pulled the lines and tried again no fuel comes out so i changed pump my self with another and still the same.. i check all relays and fuses that i could find still nothing... I was wondering is there a sensor that runs off either crank or cam that would control fuel only and not spark since i have spark and no fuel and or is there an air gap that controls fuel system that could be a miss since they changed the timing belt.. i am mechanically inclined and have some electronic knowledge as always more indepth answer would help thanks......
Mar 29, 2009 at 10:25 PM
