Engine Mechanical problem
2005 Kia Rio 4 cyl Two Wheel Drive Manual
Dear sir/madam,
I’ve a problem with my Kia Rio LS engine:
Suddenly, the engine had locked with white smoke coming out from the Exhaust. When i opened the engine, found that 1st Connecting rod ( on first stroke) is slanted and deformed!. Also cylinder #1,#2,#3 had some oil in them.
It seems that accumulation of oil at cylinder #1 causes the stroke to be locked before top position and then causes the connection rod to be slanted.
1st question: is the above theory True?
2nd question: what cause the oil to be pumped to the cylinders through Manifold ( I found that the oil is pumped Through the Manifold! because this path was oily and cylinder head and it's washer had no problem).
I’m concerned that if I change the damaged parts and fix the engine, the problem will occur again
Please guide me...
And another thing... before the problem, my car was parked on a high horizontal slope and engine was turned on, May this cause the oil to be passed to the manifold!!!!!
sp thanks’
Kambiz.J
Dear sir/madam,
Please guide me...
sp thanks’
Kambiz.J
Aug 19, 2009 at 5:42 AM
