my kai blew the head. i had it resufaced and pressure tested. i have it reinstalled now. the valve timimg is set. i replaced all the gaskets and the cam position sensor. had to buy new battery. during clean up i wiped off the firing order. but the car will start. i have to pump the trottle as fast as i can while tirning the key for 30 to 60 seconds before it starts. the first time it started it sounded good except after idle when i accelerated the engine stalled a moment before increasing rpm. since then i put the belts, air filter and timing cover back on and now it will bearly start and when it does it sonds loaded down. if i take my foot off the gas pedal it dies. what should i do to fix this? also can you tell me what the firing order is on the coil
Aug 26, 2009 at 2:34 PM
