2004 Kia Rio No Spark
2004 KIA RIO
OHIO28
  • 16 POSTS
Electrical problem
2004 Kia Rio 4 cyl Front Wheel Drive Automatic
In test staring the car, does the alternator have to be hooked up inorder for the car to start. Or is the battery enough to produce the spark the car needs to start?
(I am replacing a timing belt and I haven't hooked up the alternator yet. But I noticed the car does produces one spark and thats it.)
Thanks again, donations on d way..
Ohio28
Feb 25, 2009 at 11:33 AM
DAVE H
  • 13,384 POSTS
Hey Ohio
I've looked at the pictures, the pistons do not look that bad .. i've seen a lot lot worse and they still worked fine !! .. a good clean up should do the trick .. make sure there is no debris left in the chambers and no scoring .. but by the sounds of your last post you already have it rebuilt ? .. the alteranator does not need to be hooked up as long as the battery has a good bit of power left in it .. the alterantor will not start working untill the engine is actually running .. let me know how you go ?
Dave H
Feb 28, 2009 at 4:11 PM
DAVE H
  • 13,384 POSTS
Dave hey and thanks for the information, it was very helpful on decissions for the future. Had the head redone, and all 16 valves were bent, but the rest of the head was fine. My question now are to make sure the shop that put this head back together has everything back the way it needs to be. For if it's not, I can line up the timing marks and the same thing can happen. I have attached picture for the questions I have for this model. Question: (on all pictures the left is the intake manifold side, and the right is the exhaust manifold side of the cyliner head). On picture 100_1380, shows the top side of the cylinder head. Should the longer cam go to the intake manifold side? On pictures 100_1377, 100_1378, 100_1379, How should the pulleys go back on both cams? The cam pins should be facing which mark on the pulleys, E or I? Dave Thank you and May God bless you and all who knows you bro, OHIO28 Hey Ohio The camshafts look good to me !! .. Install the camshaft pulley. Tightening torque: 55.0~77.4 lb-ft (74.5~104.9 N-m, 7.6~10.7 kg-m) Fig. 64: Installing The Camshaft Pulley Courtesy of KIA MOTORS AMERICA, INC.
https://www.2carpros.com/forum/automotive_pictures/266999_cam_10.jpg
Check that "I" mark on intake camshaft pulley is aligned with mark on seal plate and "E" mark on exhaust camshaft pulley is aligned with mark on seal plate. Fig. 65: Aligning Camshaft Timing Marks Courtesy of KIA MOTORS AMERICA, INC.
https://www.2carpros.com/forum/automotive_pictures/266999_cam2_7.jpg
Let me know if you need any more information !!
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_189.png
Mar 11, 2009 at 8:21 PM
