2003 Kia Rio
2003 KIA RIO
ANASTASIIA
2003 Kia Rio 4 cyl 90 000 miles
When Im driving on highway my steering wheel is vibrating(not when im pushing brake, just when im driving). When i do like 30-40 miles i dont have this problem. Whats might be wrong? Thanks
Sep 28, 2010 at 10:12 PM
DAVE H
  • 13,384 POSTS
Hello .. thanks for the donation .. much appreciated
Start by having the wheels balanced and the tires and rims checked for damage.
Sep 29, 2010 at 2:59 AM
ANASTASIIA
Thanks a lot, i had to change all tires
Sep 30, 2010 at 11:22 PM
DAVE H
  • 13,384 POSTS
thanks for letting us know your final fix .. please use our form again in the future if needed and spread the word to family and friends
Oct 2, 2010 at 4:24 AM
MAXIMILIAM
  • 436 POSTS
Have you checked the basics such as tire balance, tire condition...?
Jul 28, 2013 at 2:03 AM
MAXIMILIAM
  • 436 POSTS
Hi there,
Thank you for the donation,
the most common cause of this type of vibration is wheel balance or tyre condition problem, have these check first.
mark (mhpautos)
Jul 28, 2013 at 2:04 AM
MAXIMILIAM
  • 436 POSTS
Hi Anastasiia. Welcome to the forum. When this happens only at higher speeds it is usually an out-of-balance tire but you should feel it in the car too. Other potential causes are a broken tire belt, bent wheel, warped brake rotor, and worn inner cv joint housing.
The broken tire belt can often be felt at very low speeds and the steering wheel will move back and forth, but if it is just beginning to break, you might only feel it at higher speeds. The same is true for a bent wheel. While you'll feel it mostly at higher speeds, the steering wheel will wobble a little a low speeds. The brake rotor can warp two different ways. If there is a thickness variation at various places around its surface, that's what you will feel in the brake pedal when stopping. There can be no thickness variation but the entire rotor can be warped causing the brake caliper to slide back and forth once per wheel revolution. That can act on the steering linkage to tug it back and forth. That will be most noticeable at higher speeds. A worn inner cv joint housing is a hard-to-diagnose cause but the wobble it causes only occurs during acceleration and more so in the 5 - 35 mph range. The load on it causes the rollers to bind in the housing. That forces the shaft to push on the spindle and that tugs on the steering linkage.
caradiodoc
