2002 Kia Rio lean misfire, random misfires
2002 KIA RIO
105,248 MILES • 4 CYL • 2WD • AUTOMATIC
GEORGIA12009
I have checked compression, fuel pressure,injectors vacuumleaks nothing wrong here. short term fuel trim 39% long term fuel trim -9% o2 015
Jun 5, 2009 at 6:37 PM
A lean fuel condition can be caused by:
* Low fuel pressure due to a weak pump or leaky fuel pressure regulator. (use a fuel pressure gauge to check fuel pressure at idle)
* Dirty fuel injectors. (try cleaning the injectors)
* Vacuum leaks at the intake manifold, vacuum hose connections or throttle body. (Use a vacuum gauge to check for low intake vacuum)
* Leaky EGR valve. (Check operation of EGR valve)
* Leaky PCV Valve or hose. (Check valve and hose connections)
* Dirty or defective Mass Airflow Sensor (MAF). (Try cleaning the MAF sensor wires or filament with aerosol electronics cleaner. Do NOT use anything else to clean the sensor, and do not touch the sensor wires)
Jun 5, 2009 at 6:50 PM
SUNTHAR
i have same problem engine misfire and i replace MAF sensor now run very good
Jun 14, 2009 at 9:45 PM
