starting to drive in forward gears transmission does not shift to higher gear till kms grts to 50,high gear at just over 62 kms shift is rough,code showed a fault with the TPS could the trottle position sensor really cause this problem?? engine trouble light is on in the dash,it was reset without replacing the tps but it came on again,appreciate your input before i start to spend money----
Jun 23, 2008 at 6:19 AM
