My car is a kia pride carburetor type I Have a problem with the engine it runs fine and smooth when cold but a lttle bit slow when warm. my car has power steering and connected with the aircon compressor. I already consulted my mechanic here and already done lots of stuff with the engine but the problem is still there.
Here are the things already done to my car:
Engine overhaul
Transmission Overhaul
change belts, water pump, ignition coil,spark plugs, distributor, high tension, pcv valve, thermostat, fuel pump, Air filter, fuel filter
radiator cleaning
check and change brake pads and pistons
check vacuum for leaks but none found
Still the car runs slow as if my car is carrying a heavy load inside but only when warm
Can you help me with this i really cant figure out what went wrong with this car can this because of my aircon and steering pump belted together? Need your help pls thanks in advance
Engine overhaul
radiator cleaning
Feb 21, 2014 at 5:31 PM
