2006 Kia Picanto Loss of acceleration
2006 KIA PICANTO
RTULLY2
Smells problem
2006 Kia Picanto 40000 miles
Driving to work today (20miles, 15 of which is motorway) I was driving up the incline fron the M32 onto the M4. I noticed that the acceleration I usually have has gone I only reached 40 miles an hour by the time I leveled out and moved on to the motorway. usually I can make 60 without pushing it. For the last 5 miles of my trip it ran at the usual 65, 70. Again was very slow to get there though. Also I had to switch off the aircon as there wasa nasty rubber burning smell.
Have I broke my car? What might be wrong?
May 21, 2010 at 8:19 AM
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
May 21, 2010 at 7:38 PM
