airbag light stays on
KIA
MUPP300
I have a 2002 kia sedonna with 86000 miles and the airbag light and the check engine light stays on. I reset the computer and the check engine light went off but the airbag light stayed on could you pleas help
Apr 14, 2007 at 9:21 AM
[quote:f11c1e2c56="thebrian1"]After I installed a new set of Brian Crower Stage 2 Cams and Valve springs, I tried to start the car and it keeps dying on me. It sounds like there is not enough fuel to it but i am not sure. I'm using the stock fuel pump and I thought it might be a air vacuum leak, so I changed the IACV valve, Throttle body and still no good. The only way I could get the car to fire right was to step on the gas a little bit and then fire it up and it works. Any ideas on fixing that problem? I don't want to keep stepping on the gas pedal to start the car up. Thanks![/quote:f11c1e2c56]
Check the coolant temperature sensor and if it has one check the cold start injector and its time switch.
Check the minimun air adjustment-try raising it from the air adjustment screw.
Apr 20, 2007 at 1:38 AM
