2001 Other Kia Models serpentine belt
2001 KIA
93,000 MILES • 4 CYL • FWD • MANUAL
JUST127
I need instuction to take the serpentine belt off of my Kia sophia The alternator belt broke So I am stuck on this.
Jan 19, 2008 at 4:34 PM
DAVE H
  • 13,384 POSTS
www.2carpros.com/car_repair_information/index.htm
POWER STEERING PUMP BELT
Loosen pivot bolt, lock nut and bracket nut. Turn adjusting bolt to set specified deflection. See BELT ADJUSTMENT SPECIFICATIONS . Tighten pivot bolt, lock nut and bracket nut to specifications. See TORQUE SPECIFICATIONS .
Ensure drive belt tension is 110-132 lbs. (50-60 kg) for new belts and 95-110 ft. lbs. (43-50 kg) for used belts. Measure deflection midway between pulleys. See BELT ADJUSTMENT SPECIFICATIONS table. Adjust if necessary.
Apr 8, 2009 at 12:25 PM
