1996 Other Kia Models
1996 KIA
TORIE
Engine Mechanical problem
1996 Other Kia Models 6 cyl Automatic
MY 96 KIA SOPHIA ENGINE TURNS OVER BUT WANT START WHAT SHOULD I DO?
Mar 28, 2010 at 10:28 PM
Do below:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Mar 29, 2010 at 6:28 AM
