'05 Sportage Musty smell when AC on
2005 KIA
STARR87
  • 4 POSTS
On my wife's '05 Sportage, there is a musty smell when you first turn on the AC after sitting for a while. Also, we will get a light fog coming out of the dash vents. It does not last very long.
Is there a possible filter that needs replaced or a place that water collects and turns musty?
Thanks
Aug 23, 2007 at 3:15 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
You can have mildew and mold build up in the ducts of the A/C ?heater system, you can get a treatment that destroyse these smells, the one that i use here in Aus is a spray that you spray into the vents, it works very well, you should be able to get somethingalong the same line where ever you are. Also water can get trapped in the system, there will be a water drain tune for the A/C system make sure that it is nit blocked, the fog is moisture on the evaporator gassing off when the temp drops quickly when the A/C is turned on, so there is some moisture trapped in the system, hence the stale smell as well.
Mark (mhpautos)
Aug 23, 2007 at 5:27 PM
SERVICE WRITER
  • 9,123 POSTS
I agree with mhpautos and would add to check for a cabin air filter replacement.
Aug 24, 2007 at 6:21 PM
