BELT ADJUSTMENT
Generator & Coolant Pump
Loosen generator nut "A" and adjuster lock bolt "B". See Fig. 4 .
Adjust generator to set belt tension to specified deflection.
Tighten generator nut "A" and adjuster lock bolt "B" to specification.Recheck belt deflection after cranking engine over one or more revolutions and readjust as necessary.
Power Steering & A/C Compressor
Loosen tension pulley adjustment bolt "A". See Fig. 5 .
Turn adjusting bolt "B" to set belt tension to specified deflection.
Tighten tension pulley adjustment bolt "A" to specification.
Mar 10, 2009 at 7:42 PM
