More than likely this is a speed sensor issue.
Below you will find the info from the manual on how to replace this speed sensor as I would suggest replacing it.
The way we need to test this is check the voltage that is coming from the speed sensor and make sure there is a power going to the speed sensor.
Here is a guide that will help with this:
Below you will find the wiring diagram that will help with this info.
Please run through this and let us know what questions you have.
Thanks
Jan 28, 2022 at 6:57 PM
