2001 Kia Magentis check engine light
2001 KIA MAGENTIS
76,000 MILES • 4 CYL • FWD • AUTOMATIC
SAMHEMRAJ
  • 6 POSTS
hi
Just bought the car mention above and check engine light come on took it to the dealer and the code it was giving is that the engine running too lean , they did a vacuum test and said it was ok,check the spark plug and was ok ,they will change the fuel filter to see if that will help, do you have any suggestion for me .please all the money i had i send to purchase this car and little cash left to spend on it so can you help me please
Thanks
Raj
Mar 14, 2010 at 9:08 AM
LEGITIMATE007
  • 5,121 POSTS
well it seems they are on the right track with the fuel pressure, but your injector could be faulty ,one or more of them. engine coolant temp sensor could be fualty and egr, also the oxygen sensors, could be causing the system to run lean and the cam sensor of course
Mar 14, 2010 at 11:38 AM
