This is the only TSB issued for the kia regarding steering issues !
AMANTI & OPTIMA POWER STEERING FLUID UPDATE
TECHNICAL SERVICE BULLETIN
Reference Number(s): CHASSIS 012, Date of Issue: October 01, 2005
KIA:Amanti, Optima
VOLUME:3
GROUP:Chassis
Related Ref Number(s): CHASSIS 012
ARTICLE BEGINNING
SUBJECT
This bulletin provides information relating to the new Amanti and Optima Power Steering Fluid.
Starting 1/17/05 on 2005MY Amanti and Optima vehicles the Power Steering Fluid is designated as PSF4, and is easily recognized by its green color (see photo 1 in Fig. 1).
The previous fluid which is clear, was designated PSF3. The all-new PSF4 is currently only available through Kia Chemical Program at www.kiachemicals.com or fax orders to 1 866-KIACHEM P/N 03100 00130 (1 quart bottle).
The main difference between PSF4 and PSF3 is viscosity. Power Steering Fluid PSF4 will perform better in lower temperatures/colder climates.
It is recommended that PSF3 be completely drained from the power steering system prior to refilling the power steering with PSF4. These two power steering fluids are not compatible and should not be intermixed.
NOTE:Small amounts of residual test fluid may have been left in system components during production which may have discolored the fluid in vehicles built after January 2005 (see photo 2 in Fig. 1). This could result in the green fluid appearing to be reddish. This discoloration is not harmful to the system and no corrective action is required. Regardless of this slight discoloration in appearance, power steering systems in all Amanti and Optima vehicles built after 1/17/05 were filled with PSF4 which should be used for all fluid additions and/or replacements.
Nov 8, 2009 at 6:40 PM
