A friend replaced timing belt on my 2005 Kia Amanti - he didn't have timing tool and started car, which caused bent valves, melted wires. He replaced valves, wires, spark plugs and head gaskets. Car idled very rough after I got car back. Took to Kia dealer who replaced spark plugs (wrong ones were put in) and timing belt replaced and timing set. Diagnostics revealed throttle body bad so that was also replaced. Errors from beginning have read engine misfires - now in cylinders 4, 5 and 6. Mechanic at dealer is taking engine apart. Any ideas what could be wrong? Dealer also ran compression test - back came back with very high pressure reading - 240 - front pressure readings normal
Aug 3, 2010 at 1:14 PM
