Most of the time the button on the remove goes bad. I would try a new one first. here are the wiring diagrams for the locks so you can see how the system works, also we can do a CAN scan to see if the BCM is bad which can cause this problem as well. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Here is a link to a new remote which you can program:
https://amzn.to/3CCNM9d
Here is how to change the BCM out as well in case you need it, you can get a preprogrammed unit by searching Google or Ebay. Check out the images (below). Please let us know how it goes.
Jun 20, 2023 at 4:05 PM
