Keyless Entry Security System problem
2004 TOYOTA HIGHLANDER
131,000 MILES • AUTOMATIC
CULLCAT
My vehicle has a key-less entry system. Today I decided to check my oil and tire pressure. When I was done checking the oil, I shut the hood and got into the car to start it but nothing happened at first. Then the alarm starting going off along with a weird clicking noise. I turned the alarm off but the clicking noise continues. I read through the key-less entry security manual and tried just about everything I could, but the car still will not start and the clicking noise continues. Please Help!
Sep 29, 2016 at 11:46 AM
HMAC300
  • 48,601 POSTS
it is probably a bad relay if you can trace it down to a relay or module for that matter if it is doing it, try a different relay then if a module have it scanned for codes.
Sep 29, 2016 at 11:58 AM
WRENCHTECH
  • 20,761 POSTS
Do not forget to make sure the battery is fully charged with good connections.
Sep 29, 2016 at 12:02 PM
