Key-less entry
2002 MAZDA 323
150,000 MILES • 1.6L • 2WD • MANUAL
DANIELMAZDA
European Mazda 323 1.6i exclusive/royal sedan/saloon.
Hi, is it possible to program a remote control on this car? It will not go in to program mode. I found the relay which says Door Lock under the plastics behind the rear seats. On the aus/am model (protege) that is where the Key-less Unit is supposed to be. Does that mean that I do not have key-less entry option or do I have to look somewhere else?
Nov 2, 2018 at 11:53 AM
I have found the fob programming instructions and the security system wiring diagrams so you can see how the system works. Check the fuses as well.
Nov 4, 2018 at 11:20 AM
