There are many ways of getting the steering lock to disengage, see good video below.
https://youtu.be/4PcBuOn7d6I
If all ways fail, you will need to replace the ignition barrel.
To access the ignition barrel the upper and lower steering column covers need removing.
Then to remove the ignition barrel you will need to remove the restriction bolt on top of the barrel. See image 1 below
See video below.
https://youtu.be/F5MCOJjWQG8
Once bolt is removed next press down on the retainer and remove the ignition barrel from the housing. See image 2.
Note that you will need to turn the ignition with either the key or a different way, as explained in video 1.
Please let us know how you get along.
Cheers, Boris
Apr 4, 2022 at 2:15 AM
