Key will not turn in ignition
2004 NISSAN ALTIMA
129,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
BILLY BLONCO
My key will not turn when put it in the ignition wheel is locked. i tried to pull wheel in direction there is slight movement and jiggle key or try and turn key it still wont budge. i tried pitting a little wd40 on key to loosen up tumbler no avail. can i remove the tumbler and replace that without replacing the whole ignition switch cylinder piece?
Please help!
Nov 17, 2019 at 2:49 PM
The ignition switch is replaced as an assembly. I am sure there is a way you can replace the tumblers but it does not have a procedure for doing it.
If it has failed then I would just replace it because it is probably easier. However, once you get it out, you may find what the issue is and are able to repair it.
Nov 18, 2019 at 4:19 PM
