door lock replacement instructions
2001 CHRYSLER SEBRING
200,000 MILES
NOCAR22
My boyfriend has the car listed above around 2001-2006 (not sure of the exact year). The automatic lock has been not working for some time but the manual key part is not unlocking the door when I stick it in the drivers side. The key isn't even turning. I've inserted it both ways and nothing. Why can't I unlock the door?
Jan 4, 2020 at 8:13 AM
At this point we need to replace the lock cylinder as it is most likely locked up.
Here are some guides that will help with this:
https://www.2carpros.com/articles/test-or-change-electric-power-door-locks
However, before you do this, try spraying some WD 40 in the lock and then put the key in and work it back and forth. This should loosen it up and allow you to get more life out of it. This is only a temporary fix as it will lock up again but this should buy you some time.
Here is a guide that will help with removing the door panel when you do have to replace this:
https://www.2carpros.com/articles/door-panel-removal
Let us know if you have questions. Thanks
Jan 27, 2021 at 7:29 PM
