[quote:63991893f2="redbank"]Computer problem
1998 Isuzu Rodeo Question 6 cyl Four Wheel Drive Automatic 145000 miles
Can not remove key. The engine starts, runs & shut off properly, but the key won't turn far enough to release & pull out.
Checked all fuses & relays, power down the computer, all to no avail.
redbank[/quote:63991893f2]
I have the same problem in mine. Under the steering column there should be a black cable that connects to the ignition. Jiggle the cable (I pull it towards me) while trying to turn the key all the way back.
I haven't really had a look at mine, but it sounds and feels like the bolt is loose. Nothing serious.
Good luck! (If you do it enough, you can release it with your feet as well!)
May 26, 2021 at 1:25 PM
(Merged)
