Key will not come out
2007 SATURN OUTLOOK
166,000 MILES • 3.6L • 6 CYL • FWD • AUTOMATIC
GENE11
  • 5 POSTS
Key will not come out and shifter will not move out of park and the engine will not start. I think it might be the BCM.
May 23, 2017 at 12:02 PM
STEVE W.
  • 15,113 POSTS
Check your battery voltage first. If it tests good then check the fuses for power at both ends with a test light. you will want to check fuse PWR MOD (2 amp) in the panel at the right side of the dash, also the 10 amp air bag fuse and the RV C Sensor fuse in the under hood block. All of those feed the theft deterrent system and shift interlock.
If they are all good and the battery is good then it could be the BCM. But I would have a scan tool put on it first to be sure.
May 23, 2017 at 12:58 PM
GENE11
  • 5 POSTS
Where is the BCM located on my car?
May 23, 2017 at 1:11 PM
STEVE W.
  • 15,113 POSTS
Under the dash to the left of the steering column. But it is not a plug and play item, any replacement will need to be programmed to your vehicle for anything it controls to operate, not something most places can do as it also involves the security system.
May 23, 2017 at 7:36 PM
