Check your battery voltage first. If it tests good then check the fuses for power at both ends with a test light. you will want to check fuse PWR MOD (2 amp) in the panel at the right side of the dash, also the 10 amp air bag fuse and the RV C Sensor fuse in the under hood block. All of those feed the theft deterrent system and shift interlock.
If they are all good and the battery is good then it could be the BCM. But I would have a scan tool put on it first to be sure.
May 23, 2017 at 12:58 PM
