The first start of the day requires multiple key turns, after that, starts, runs fine all day?
1994 LEXUS ES 330
48,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
BOB7444
The problem has existed for about 6 months. First start of the day requires multiple key turns. After that, starts, runs fine all day. Next day, the problem repeats. Presently, multiple key turns produce nothing-no sounds, just dash lights. Battery, alternator, starter, neutral safety switch are all good.
Nov 20, 2023 at 6:44 AM
There is a starter relay I would swap out, here is the location of the relay and I have included the starter wiring diagrams so you can see how the system works. If you swap out the relay and you still have the problem I would see if the starter trigger wire gets power when the key is in the crank position. This guide can help:
https://www.2carpros.com/articles/starter-not-working-repair
Nov 20, 2023 at 8:40 AM
BOB7444
Hello Ken, Thank you for the help. The relay turned out to be the problem.
Nov 20, 2023 at 2:59 PM
Thanks for letting us know, we are here to help, please use 2CarPros anytime.
Nov 21, 2023 at 11:06 AM
