My sister's car listed above is having issues. It throws codes for lean condition, the cat, misfire and injector. It also had a starting problem at times. It also was running kind of rough. I decided to get her a new PCM. When the car would act up, I would simply pull the ECM/PCM to reset it and the car goes back to normal. Based off that I decided to get a new one and have it programmed. Last month the car acted up and the key would get stuck in the ignition at the same time the windows stopped working all together. I replaced the PCM, and the car starts and runs but the key still gets stuck, and windows don't work. I have no clue what can be wrong or what else to look at. The battery was replaced 5 months ago. The charging voltage is in range, it starts and runs with no issues. All fuses are good. I don't know if the new PCM is bad, the chip in key is faulty, the body control module is bad or a mix of multiple things. What do you guys think? FYI, did do the key cycle multiple times. Also, the car was sitting with battery disconnect for a month to prevent it from draining. I also know how to remove the key and turn to off position by that little latch under wheel.
Sep 16, 2022 at 2:55 PM
