Key gets stuck in ignition after driving, but will turn and come out after just a minute or so after the car is shut off. Wheel lock is not engaged, shift lock is not engaged, tumblers and key look good, not a key cylinder problem. Thinking it is an ignition lock solenoid issue. But am unsure of how to replace it. Maybe a shift lock solenoid issue. I am thinking it is a solenoid issue because the key comes in/out no problem before starting, then gets stuck in "on" after driving for a while. Giving the car 2 minutes to cool off, solenoid cooling off too, the lock disengages. Make sense?
Jun 12, 2020 at 2:56 PM
