I replaced the ECM and Throttle body/Throttle Position Sensor and tried the key relearn process and it didn’t work.
The Security light on the dash isn’t staying on at all during the relearn process. It turns off with the rest of the lights 20 seconds or so after turning the key to run position.
Is it possible that the key relearn process isn’t working due to a bad Ignition lock cylinder which would also cause the security light not to work? The cylinder gets jammed and has trouble turning sometimes.
Jun 6, 2023 at 2:37 PM
