Key ignition switch
2013 HYUNDAI SONATA
56,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
MARLAINEGARCIA
  • 7 POSTS
Unable to turn key to remove it the from ignition switch. So, I disconnected the cable to the battery to keep from draining my battery. Only then will the key come out of the switch. Won't turn pass axillary position.
Jun 17, 2020 at 3:49 PM
I'm trying to understand. The key will come out of the switch when the battery is disconnected? Is the shifter lever engaging fully into park? Can you hear the park interlock actuator click when you press the brake pedal?
If you look at the attached pic, it shows how the interlock and ignition work together.
Jun 17, 2020 at 7:06 PM
MARLAINEGARCIA
  • 7 POSTS
Yes, the key will come out once battery is disconnected. Yes, the shift lever seems to engage fully into park. But not sure about any sound from the actuator. I'll check on it on the morning.
Thank you very much!
Margaret Garcia
Jun 17, 2020 at 7:17 PM
You are very welcome. Let me know what you find.
Jun 17, 2020 at 10:56 PM
MARLAINEGARCIA
  • 7 POSTS
Hello, my husband just checked each fuse in the motor box, none are burned out. But, was unable to check the relays. The gear shifter and brake does make the clicking noise when it engages. What now?
Jun 18, 2020 at 10:18 AM
Okay, I have one last fuse to check and what will sound like a stupid question. The fuse is in the vehicle (see pic attached). The stupid question is this. Are the brake lights working?
Jun 18, 2020 at 8:54 PM
Can you confirm the ignition is in the lock position? Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
Jun 18, 2020 at 9:23 PM
MARLAINEGARCIA
  • 7 POSTS
Yes the brakes lights work.
Jun 19, 2020 at 7:48 AM
Okay. I know that sounds like a crazy question, but the brake switch is what releases the lock. Have you checked the other fuse I suggested? Also, is it possible to upload a video as Ken mentioned?
Jun 19, 2020 at 8:51 AM
MARLAINEGARCIA
  • 7 POSTS
Thanks for your help in this matter. I'm heading to my mechanic today and he will run a diagnosis on it.
Again thanks, great service you have provided. It helps me to understand more. Have a great day!
Jun 19, 2020 at 9:39 AM
Please let us know what they find we are interested to know.
Jun 19, 2020 at 10:24 AM
MARLAINEGARCIA
  • 7 POSTS
I sure will.
Jun 19, 2020 at 11:51 AM
Just an FYI... I did some additional research on this issue and think I found a solution. There is a micro switch on the side of the shift assembly (under the trim) that has a simple steel tab that actuates when the vehicle is in park. It seems the metal tab bends and prevents the switch from releasing the interlock in the column. If you are told to replace the entire shift assembly, let me know. I will try to walk you through checking and repairing this issue.
Jun 19, 2020 at 8:46 PM
MARLAINEGARCIA
  • 7 POSTS
Hello, okay finally got my car back. it was the solenoid switch to the key ignition. All is good now and I was told to make sure I remove the key more slowly, in case I'm pulling it out to quickly.
Thank you for your advice and help in this matter.
Margaret Garcia
Jun 25, 2020 at 12:59 PM
JACOBANDNICKOLAS is one of our best! Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
Jun 25, 2020 at 1:10 PM
