Transmission keeps popping out of fourth gear
1996 TOYOTA TERCEL
187 MILES • 2WD • MANUAL
SLOANRANDI69
Had fluid toped off and it still pops out of 4th gear.
Aug 10, 2021 at 4:17 AM
MASTER ASE TECH
  • 82 POSTS
Hi, I'm Dan.
It sounds like it is most likely an internal issue inside the transmission. Something like a worn shift fork or detent ball. I've attached a form from Toyota that shows the likely areas to check. I've also attached an exploded view of the transmissions internal shifting mechanisms.
https://www.2carpros.com/articles/how-a-standard-transmission-works
Aug 11, 2021 at 12:26 PM
