I recently did an ohms test because the system was reading 120ohms. i disconnected the k73 x2 connector telematic module because it stop reading 120ohms, but still had an open circuit. I did the same test on the bcm module, i disconnected the x6 connector and the ohms read zero. My question is: is the bcm bad, or the path(wiring) to the telematic comm bad?
Jan 11, 2026 at 7:26 PM
