Replacing the valve cover gasket does involves removing several parts. It is not terribly difficult and can be done mostly using simple hand tools. You will need a torque wrench unorder to torque down the valve cover bolts properly.
Here is a helpful article:
https://www.2carpros.com/articles/replace-valve-cover-gasket
I have attached the complete replacement procedure for your reference.
Thank you.
Sep 14, 2021 at 9:52 AM
