Hello, at the below link, you advise - how best to 'fix a battery draw'.
https://www.2carpros.com/articles/car-battery-dead-overnight
On 'Step 5' - you say :
-Then take you voltmeter and set it on the DC amp scale.
-Then attach the red lead to the battery post, negative. -Take the black lead and attach it to the battery cable.
-Use a small jumper wire along side of the voltmeter and wait for 15 minutes to allow the modules to go to sleep.
-Then remove the small jumper wire leaving just the voltmeter. Then look at your reading, it should be about 50 to 75 milliamps.
Just to check with you, when you say 'Use a small jumper wire along side of the voltmeter ' (and wait 15 minutes - then remove it- leaving just the voltmeter)
Do you mean exactly like in the diagram that I have attached to this message? (see image)
Thank you in advance.
Regards,
Ian
Regards,
Ian
Apr 7, 2020 at 2:45 AM
