noise after replacing wheel hub assembly
2001 DODGE DAKOTA
140,000 MILES • 4.7L • V8 • RWD • AUTOMATIC
RACHEL DOWNING
  • 5 POSTS
just replaced wheel hub assembly on both sides of front. Passenger side was worst of the two but did em both regardless. Now I am hearing the bearings on that side again I do not get it. In addition to that, now there is this crazy clunky nose there too when ever I drive over even the slightest crack or even barely bump. That noise is quiet at high speed on smooth freeway, but main roads is crazy. I do not know what to think.
Apr 9, 2017 at 3:47 PM
I would recheck the brake caliper so make sure it is tight or maybe it is touching the rotor due to a spacing error in the bearing hub, please jack-up the side that is making noise and spin the tire to see if you can hear something.
Hear is a guide that will show you how to do the job so you can do over it to see if you missed anything.
https://www.2carpros.com/articles/bearing-hub-replacement
Best, Ken
Apr 9, 2017 at 5:45 PM
RACHEL DOWNING
  • 5 POSTS
Right on the dot. Thanks
Apr 10, 2017 at 2:53 AM
All fixed? What was wrong?
Apr 10, 2017 at 10:24 AM
