Purchase a second hand steel wheel and tire, center bore is damaged and not circular
2013 SKODA OCTAVIA
110,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
CARDIFFMAN
Just bought a second hand steel wheel and tire to use as a spare as none with the car.
The center bore is damaged and not circular like a potatoes) is it safe to use?
Thanks in advance
Jun 27, 2019 at 7:12 AM
Hi Cardiffman,
The center hole is just a centering hole that goes around the hub. As long as the wheel goes on the studs and bolts down flush to allow the lug nuts to tighten properly, then it is okay. Even though it may be safe, this issue may cause a vibration but again, the safety issue will come in if the tire does not not sit flush on the rotor or the lug nuts are not tightened properly.
The other thing you need to worry about is if the wheel is bent. I would take it to a tire shop and ask them to balance it and measure runout. This will tell you if there wheel itself is true and it is just the center hole or the wheel is no good.
Hopefully this answers your questions.
Jun 27, 2019 at 6:10 PM
CARDIFFMAN
Thanks a lot!
I will try the wheel on and have balanced.
Regards, Cardiffman
Jun 28, 2019 at 7:27 AM
Sounds good. Let me know if you have other questions about this issue. Thanks
Jun 29, 2019 at 10:25 AM
